メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
Why does my mac freeze, then flash folder with question mark?
Often my mac freezes completely, and when I reboot it can’t find the startup drive (flashing question mark folder, disk utility does not see boot drive). After a few hours, it will boot normally. The problem comes and goes, but has been happening about every other day for a week. Running an Apple Diagnostics test gives error codes PPN001 and VDH002, but sometimes it gives no errors.
What is going on? I think the SSD works because other than the above issues, everything works well (runs fast, no problem opening/closing/saving files). Is this a cable issue? How can this be fixed?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
最も参考になった回答
That issue is to do with the storage drive not being detected via the system. It seems a bit odd that is only happening a part of the time. I’d recommend re-installing Mac OS and backing up all important data and see if this helps. If it doesn’t then it might be a physical problem with the drive itself, if this is the case open your laptop up with help from this guide: MacBook Pro 13インチ Retina Display Late 2013 底ケースの交換
Inspect everything and see if there is anything around the ssd and/or ram that should not be there (Dust, corrosion ect.) . If there is, remove the component, clean it with rubbing alcohol and remove what should not be there, then and re-install it. Boot it up and if it still doesn’t boot you may have to replace the drive altogether. You should also check any cables in the system to see if there are any tears in them.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I would give a new SSD a try. If it turns out that a new SSD does not solve the problem then you can return it back to iFixit quickly and easily.
[リンクされた製品が存在しない、もしくは無効: IF123-123]
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Once you have it booted, go under the Apple in the upper left hand corner to >
System Preferences >
Startup Disk >
unlock it > select your internal drive >
close lock and restart and see if your problem persists
UPDATE
It sure makes us look stupid when you change the question after an answer has been given instead of adding new information as an update to the post!
Apple says
VDH002
There may be an issue with a storage device.
PPM001
There may be an issue with a memory module.
I would reformat the drive after booting from an external USB drive and try reinstalling the system. That failing go to @ajcooke01 Aaron’s solution.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sorry about that! I just thought the edit might be more helpful, thanks for the answer
さんによる
コメントを追加
In the event that you see a blazing question mark on your Mac's screen at startup, it implies your Mac ... On the off chance that your Mac shows a blazing question mark for a couple of minutes however then ... Your Mac should now start up without the blazing question mark (click here). ... things in your home organizer like your reports and things on your work area
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am experiencing the same problem, did you manage to solve it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can some body answer if this problem was solved changing between ssd?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes it was. Using a adata ssd with sintech adapter now. Works perfectly since.
さんによる
コメントを追加
回答を追加する
Dimitri Coukos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 8,661
