Why laptop keys single press give multiple same alphabets?
My laptop keys are not working properly..every time I use keyboard and press single key the alphabets appear on their own.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Did you try an external USB keyboard connected to the laptop to check if it works OK and that the problem is with the laptop keyboard and not the OS?
Assuming that you have Win 10 OS installed in the laptop check the keyboard settings to ensure that they are set to suit and are not the cause of the problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 393
2 件のコメント
Hi,
Does it happen on all keys, keys in a single row or column or just a couple of individual keys?
Has any liquid been spilled onto the keyboard?
Try connecting a USB keyboard to the laptop and see if it happens when you use it to type etc.
What is the full model number of your laptop?
jayeff さんによる
Its happens to all the keys.nothing has spilled on it.my laptop model is Haier Y11C.it has tab mode too..tab keys work finely.only keyboard keys are not working
Fatima Noreen さんによる
