Can I upgrade Core i5-2400S to Core i7-2600?
it is possible upgrade Core i5-2400S to Core i7-2600?
As long as both are the same mount...
*After some googling*
They are both LGA 1155, so yes, it can be upgraded.
このアンサーは役に立ちましたか?
Gabe - did you find anyone that has done this successfully? Just because a chip fits doesn't mean it will run.
Touché. Well theoretically, if its the same bus speed, etc, it will run? I vaguely remember someone upgrading their processor from 1066 MHz to 1333 MHz because the bus was on the processor on a mac once.
The i7 is sandy bridge and the i5 is an older process. I wonder if there might not be firmware problems.
OS 10.6.7 has to be able to support the intel core i 7 2600... google that first
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 4,566
1件のコメント
http://www.cpu-world.com/Compare/498/Int... has a comparison for both. Just does not look like a whole lot of improvement and checked the cost of the difference, seems steep for the difference. Good Luck
oldturkey03 さんによる
