メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod Original、Mini、Shuffle、Nano、Touchを含むほぼiPod全モデル用の解体ならびに取り付けガイドです。
締切られた回答
If I delete itunes...
will it delete all my music? even the ones purchased from itunes? I do plan to reinstall itunes, just a later version.
ADMIN EDIT: Here is the entire context for the question. For those of you who are answering, please look at the context of the question to best answer: first, second, third, forth, fifth, sixth, seventh, eighth, ninth.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
By default, the music you have in iTunes is stored in the "Music" folder in your user folder. That's a different place from your Applications folder, so if you tossed the iTunes application, it wouldn't junk your music.
However, you should confirm where your iTunes program is storing your music by going to the Advanced setting in iTunes Preferences. A window there should show you your iTunes music location. Just make sure you don't throw away that folder to ensure you're not deleting your music.
But more to the point, if you just want to upgrade iTunes, you shouldn't have to delete the program. Just use Software Update to download and install the latest version of iTunes. It should replace your old iTunes with the new program without deleting your music files.
(It's always a good idea to do a backup before upgrading, though, just to be sure.)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Well my iPod wont restore. And i get error 1437. So what information i couldnt get from here, other posting sites have said to try downgrading iTunes. At this point i will try anything.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,744
