メインコンテンツにスキップ
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
280回答 すべてを表示
Pioneer VSX-531 Receiver does not power on (HDMI light blinks)
Pioneer VSX-531 AV Receiver
5.1-channel receiver with 5x130 Watt, 4 HDMI ports, HDCP 2.2, MCACC automatic calibration, Advanced Sound Retriever, Bluetooth and USB
I have a digital copy of the user manual | Need a schematic or wiring diagram
Expert researcher / Novice electrical repair experience (I know enough not to be dangerous, and can fix most basic electronics given enough time)
Source: Found “Free” on OfferUp
Issue:
  • Unit does not power up
  • When plugged in, HDMI light flashes (indicating error state)
  • No other lights illuminate, standby/on button doesn’t function
Error Diagnosis:
(Per user manual): The HDMI indicator blinks and the power does not turn on.
  • The receiver may have a serious problem. Do not try switching the receiver on. Unplug the receiver from the wall and call a Pioneer authorized independent service company
  • That’s helpful…?
Troubleshooting:
  • Able to temporarily clear error by simultaneously pressing “Advanced Surround” and “Standby/on” for 5 seconds
    • After doing so, unit clicked, initialized, something got hot & smoked for a second
    • Unit went back into safety power off
    • Back to HDMI flashing error state
What I’ve done:
  • Isolated component that was getting hot (smoking): Resistor R14FL
  • Uninstalled the MOSFET / heatsync daughter board (720-07995-000-0S) from the unit, this board contains the overheating resistor
  • Resistor tests same ohm resistance (.34) as adjacent resistor on neighbor MOSFET
Pix
Burning Resistor (circled in red)
Photos of the MOSFET / heatsync daughter board (720-07995-000-0S)
Really appreciate any help that the forum can offer :-)
Cheers,
Lou
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Thank you very much, your answer was helpful, with appreciation.
さんによる
Hello sir i was wondering did you ever end up figuring out the pioneer reciever. I had mine over heat also going into protection mode. Same resistors went out and that channel the transistors were bad too. I replaced them all and then soldered it all back together and reset it and the protection still comes on. Im at my witts end. Any insight would be great i really thought i had it whooped. I was able to download a service manual off manuallibs or something and its for a vsx530 and had very similar boards and parts so ive been hsing it to check curcuits.
さんによる
Hi - I had the same issue where the HDMI light flashes and the unit turns off. I tried a factory reset, and now it won’t turn on at all (makes the click sound when you press the power button and then the similar power down noise). Any ideas?
さんによる
コメントを追加
2件の回答
最も参考になった回答
What makes this a bit tricky is that the component labels on the board do not match the schematic. Can you post the numbers on the transistor to the left of the circled resistor in your picture? Also, what are the color bands on that resistor and the one next to it?
This portion of the board is for the front left channel of the amp. It looks like the outputs for that channel are shorted and causing the amp to go into “protect” mode. Can you test the transistors in that area for shorts? These should be numbered B1560 and D2390 (on the parts themselves). This is shorthand for the actual part numbers: 2SB1560 and 2SD2390.
With the transistor number requested, I can verify that I am at the correct point in the schematic.
Thanks,
Dan
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
so I have the 531 as well and did the exact same thing so I van uninstall that peice and it will still work fine? please could really use the help I just bought this from craigslist and it has the same problem you just posted
さんによる
コメントを追加
I had problem too I did the advanced surround and standby buttons hold for say ten seconds and it clicked back on and works great again!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you. It worked too on my end. Just seconds before I run to the service center. Good thing, I did a quick web search and found ur comment
さんによる
This really works
さんによる
コメントを追加
回答を追加する
Lou Bolanis さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 81
今までの合計 13,863
