Laptop hinge screw Brass bushes
I’m trying to find a supplier of the small brass bushes that the screws screw into under laptop hinges etc. does anyone know who / where i can get them from? I’m constantly fixing broken hinges so want to keep a stock of spares. I’m in UK BTW.
many thanks in advance
Kelvin
この質問は役に立ちましたか?
2 件のコメント
You mean the brass bushes which are a press-fit into the plastic shell? In my limited experience it's the plastic shell that breaks, with the result that the bush falls out. I've effected some kind of repair once or twice with 2-part epoxy glue around the broken plastic and in the hole to hold the bush in its hole.
Philip Le Riche さんによる
Yes, thats the ones. I do the same using epoxy glue to 'rebuild' the broken plastic, but I have had instances where the brass bush is missing, so want to keep a stock of them so I can replace them.
Trying to find a supplier of these [in the UK] seems to be like trying to find a screw that youv'e dropped on the floor during a repair !! :-(
Kelvin Wilkie さんによる
