My dyson was working, lost power and smelt like it was burning
why would it slow down with power and smell like something’s burning?
Hi @plane53 ,
Check that the cannister is empty and not clogged and that the filter is clean so that the motor will get good airflow through it.
If it gets too hot it could automatically be turned off by a thermal cut off switch in the motor to prevent the motor from burning out.
Wait until the motor has cooled down and then see if it works OK.
このアンサーは役に立ちましたか?
My dyson was not working, lost power and smelt like it was burning.
Can do any repairs
filters all cleaned and everything clear
how do I get to Carbon
also when I get wheels off there is hard plastic with screws
Look at your motor ‘s carbon.. i Ve just disassemble my dyson, smell like burn , but it’s broke carbon powder.
このアンサーは役に立ちましたか?
After full cleaning,and test my motor have one loop burn.. so new motor needed..
For brayden s , i have disassemble the turbo bin box, you need to unscrew all screw to accès to a join for block airflow that is broke too.
I havé buy a sheet of neopren and cut like the original , replace and reassemble all part
ive had the same situation before with my parents theres a band somewhere it must have damaged or is needing replacement
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 20
過去 30 日: 78
今までの合計 3,985
1件のコメント
waiting for a answer, was told to go to this website
Pat Anderson さんによる
