Laptop won’t turn on
I have a Toshiba satellite l505d, at first when I hit power button lights and fan turn but not screen no boot up, I tried a few times and it will start, but no metter how manny times I tried it don’t don’t start
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Does the disc drive start moving with a disc in it? If it stays powered with the fan on I doubt its anything to do with the power supply. It could be a loose LCD flex cable, laptops tend to have LCD connection problems after years of use. Try connecting it to another monitor with a VGA cable if it has a VGA output to project to another screen. If that works then its the LCD or the flex connection. If not then it could be a fatal motherboard issue.
このアンサーは役に立ちましたか?
sometimes they overheat, I have inspected some and they have heat marks
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 333
