メインコンテンツにスキップ
モデル:CUH-ZCT1は、2013年11月にSony Computer Entertainmentから発売されました。このコントローラはSix-axis、3.7 Vリチウムイオンバッテリーを採用しており、修理は複雑ではありません。
387回答 すべてを表示
PS4 controller is dead - Battery and USB port already replaced
As described in the title my PS4 controller is dead. The battery is charged, but the LED’s don’t turn on, even with USB cable connected. I already replaced the battery and I also replaced the lower part of the controller (the one with the USB port) with one of a working PS4 controller, which brings me to the conclusion that the main part of the controller (the one with the motherboard on it) must be damaged. I couldn’t find any visible damage. You should also know that, after I took the controller out of the closet to start repairing it, after I put the plug in, the controller worked once with LED’s blinking, but not anymore after I pulled the plug out.
I looked all over the internet to find a guide on how to repair the motherboard or anything related but I couldn’t find anything. You are my last resort. Thanks in advance <3
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
i presume you've tried resetting it ?
さんによる
コメントを追加
2件の回答
最も参考になった回答
You could get this and repair it, seeing if it works.
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-030)
If nothing else is working then replace the motherboard on it all together.
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-030)の画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have a controller like that. The wireless, battery charging or turning on via battery doesnt work. I now use it on my desktop as wired controller. http://ds4windows.com/
You can sell it as a wired controller if it works that way, I personally dont think controllers are worth repairing.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
El Mero Mero さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 1,835
