メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2376回答 すべてを表示
Wifi and GPS Problem
Well I dropped my iPhone 4 at&t in water and the mic for video and the wifi stopped working and my GPS started giving very vegue location services. Recently my mic started working but the gps and wifi stayed the same... Recently i took my iphone appart because the LCD connector came loose and i had to fix it... After reasembly i realized my wifi was working but very weak and my gps was the same... So i have two questions... 1. Where are the screws that ground the wifi ive heard they could be the problem and 2. Should i replace my wifi antenna or something else?
PS. I had my phone repaired at some shop and they lost some screws and they lost the pressure/connector thing near the battery connector if that makes a difference.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Check the screws around the EMI shield (the shield that covers the 5 connectors on top). That is your wifi antenna.
Replacing the 'wifi antenna' does not solve this problem as this is not actually the wifi antenna as many sites suggest but it is the GSM/GPRS/3G antenna instead.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Richard Collins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 3,220
