メインコンテンツにスキップ
Lumia 950 XL is a Lumia flagship introduced in 2015.
2回答 すべてを表示
Lumia 950 XL screen issues
Phone Works Fine, Screen doesn't have any damaged, touchscreen works fine.
But I have an issue with my phone, my phone screen blinking to the blank every couple seconds.
When I don't use my phone and it goes to standby mode, the screen goes to the green color, but when I wake up phone screen come backs to normal colors, but screen still blinking every 2 seconds to blank.
But when I do updates or restoring the phone,due that process screen work fine, screen doesnt blink at all and all colors looks fine.Blinking just happens when I use phone.
I tried connect my phone to tv, everything works fine.
So I guess is not hardware issue, but also I dont think it is software issue also, because I tried install different versions of software and it doesnt fixed my issue.
Anybody have an idea what could make this issue?
Any suggestions How can I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi!
Have you dropped it or has there been any water damage?
You can try to reflash the firmware of the phone with this tool from Microsoft (it will revert all updates and format the phone and the firmware then install everything anew): https://support.microsoft.com/en-us/help...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Nope I don’t dropped it and its doesn’t have any water damage.
I tried that software, i tried different version of firmware, but problem still exist.
I would think it screen problem, but when I do firmware update, screen never blinking or makes any issue.
It happens just when windows loads and after windows load it happens all the time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
petras18 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 768
