メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Restore successful but boot loop
Hello.
So i get this iPhone 7 on my desk, with water damage, very light corrosion here and there, cleaned and replaced the caps who seemed damaged, now the phone charges normaly (~1A on a 1A charger).
The iPhone turns on and after ~5 second resets itself, so i thought i might be the iOS that is the problem, so i restored with iTunes to latest version, all went well no errors the screen was lit the entire time with the Apple logo and the progress bar. After the restore finished, the iPhone went down and turned back on, but still the boot loop after ~5 seconds.
I repalaced/rebaled the Tristar and Audio IC’s also measured all the relevant main voltages. Also tried to turn on the phone without all the flexes… still boot loop.
Any hints?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Short boot-loop is usually BB related but with a water damaged phone, who knows, it could be anything. did you remove the shields when you did the decontamination?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I removed the shields and cleaned everything but no corrosion what so ever. If it where a BB related problem would it not trigger a restore error? I had this kind of a problem before with a iPhone 7 where the problem was a defective/water damaged proxy flex...
さんによる
I agree, BB issues should give an error code during restore but when faced with no answers, you have to try something :>).
さんによる
コメントを追加
Hello, did you solve problem? I have same issue, little corrosion, bootloop, when i resolder audio with jumper does not help :) yeah and restore without error
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dacian Bujor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 263
