メインコンテンツにスキップ
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
46回答 すべてを表示
Popping/clicking while my tv is on
WhIle my tv is turned on it perodocally clicks or pops. Other than the clicking it works perfect and nothing happens when it clicks. It just has an off and on click. It doesn't happ er n all the time but it is annoying when it does. Anyone know what may be causing this to happen?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
ladylyn7  clicking is usually related to relays on the power board. Since you do not have any issues and your TV continues to work with failure, I would wait for things to actually stop working. Otherwise, you will have to remove the back of your TV and to take a look at the boards to see if they are starting to develop failure. You would need to check components and traces for obvious damage like domed or leaking capacitors etc,.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
ladylyn7 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 57
