メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
425回答 すべてを表示
USB charging extremely slow after external battery pack quit working
i had a blackweb bwc17w1004 20,000mAh battery pack that while it was plugged into the phone quit working (the charge indicator will not light, no indication of charge when a device is plugged in) now my phone (Samsung Galaxy S7 SM-G930A) takes upwards of 18 hours to charge via USB, (requires the phone to be powered off as it consumes more power then charging can offer) also there is no sync connection when connected to a computer, Wireless charging works fine, the battery is draining 3 times faster since this happen, will replacing the charge port connection on this phone fix this issue, or could it be on the main board, i really don’t want to replace this phone, it has worked so well i have had it for over 2 years without ever factory reseting the phone, it was working great tell this happen, now it’s slow, and the battery drains fast. (normally 8 hours at work would go from 100% to about 40%,, now it’s dead by lunch) since the wireless charging works fine (fast charge appears on the screen and it’s at 100% charge within 2 hours)i am hoping that it’s the charge controller chip that is located on the PCB ribbon at the charge port itself that is blown. if so it will be a cheaper repair then replacement, however most guides i have found show that a new LCD will be needed as well because it’s so difficult to remove that it is destroyed when removed. any advice on this will be greatly appreciated thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Dustin Johnson  “Wireless charging works fine, the battery is draining 3 times faster since this happen,” start with a new battery. If that does not work then the battery pack has probably shortened the PMIC. Replacing the daughter board with the charging port would be the next step. Samsung Galaxy S7
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
i should have been a bit more clear, battery life before this happen was a-typical of a 2 year old phone, which is why i was using the battery pack, however it should not go from 100% to dead in 2 hours, i was getting around 6 to 8 hours out of a full battery, when i got the phone i would get at least 20 hours out of a full battery, i will look into replacing the charging port board, thank you
i hope i am able to remove the front LCD without shattering it like in the repair videos i have seen.
さんによる
コメントを追加
回答を追加する
Dustin Johnson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 413
