Replaced backlight. Now screen is black and lines appear.
Ok so I replaced my led back lights but when I put back together my led lights turned on and screen was black. Then at bottom mid of screen redish yellow vertical lines start slowly appearing. Tv automatically turns on as soon as I plug it in. I do not believe I damaged the panel. I however unplug the t con board while tv was on and lines go away and theirs a solid black screen with back lights working. However, I'm Not sure if I install the fuser films and sheets in right order or not. I think I did but not positively sure. As soon as I get a day off work, I will post pics/ video.
Update (09/07/2018)
There's also no sound. When I plug it in tv will immediately turn on, on it's own. I can't choose a channel, do not see any display nor sound. The longer I leave it on the more lines show up on the tv.
@jerelbug
wel'll have to wait until you post some images. If you are not getting any audio, it is unlikely that this is related to the diffuser sheets etc. If you do have audio get some polarized sunglasses and take a look at the screen. If you can see it, your diffuser sheets etc, are wrong. It does sound more like a board/ connector issue.
oldturkey03 さんによる
I'll try to get some pics/ video by the end of this weekend if not sooner. Thanks for responding quickly oldturkey03.
Johnathan Buggs さんによる
