メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
796の回答 すべてを表示
new screens "Searching" indefinitely. (Old Screen Works)
hi there!
we have an SE run through our store, and well, the titel says it all.
we tried 4 new screens, and they all had an indefinite searching issue.
we put the old screen on, and it instantly connected to the network.
i have uses the “Airplane mode off/on” from the old iphone 4/4s. this does not rectify the situation
im curious if apple has made another forced obselence update?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
i have had it happen on other models but turning aeroplane mode on and off solved that problem
さんによる
yeah, that used to be a thing for the iphone 4/4s. unfortunately this doesnt fix the issue for this. thankyou for the update though. ill add that to the list of things tried
さんによる
Intereresting because the antenna is not in the screen, rather in the logic board. I would have said it would be the antenna but you replaced the screen, not the Logic Board.
さんによる
i know. this is why it is weird. if i put the old screen on, and it didnt work, i would have been able to chalk that up to technician error.
But unfortunately, (and forutitously at the same time) it works fine with the old screen. this is what confuses me.
さんによる
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
選択されたソリューション
The iPhone 5 had a similar issue. It was only solved when you do a reset through dfu. After doing so it would give a no sim error. After removing and reinserting the sim it would work normally. I’m not quite sure if you would want to try this with the SE. but it is a major headache. Sometimes apple gets on my nerves.
この回答は役に立ちましたか?
スコア 1
コメント:
i did hundreds of iphone 5s, and i never encountered this. thats likely why i didnt think to try it. ill email my customer and suggest giving it a shot. thanks for your help
さんによる
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 65
