My sandisk power button
i press the power button but nothing happened it was charged this morning so what do i
do
Make sure your SanDisk is working when connected to a PC, and then try to restart it.
If it is recognized on PC , try these methods.
このアンサーは役に立ちましたか?
Make sure your SanDisk is working when connected to a PC.
1. Connect the player to the PC.
- The player should turn on, show connected on the screen and indicate it is charging.
- Some USB ports may NOT provide enough power, try the back USB ports if it's not working.
2. Make sure the computer detects the player.
NOTES:
- If the player is not detected or turning on, force the player to MSC mode, then connect it to the PC again.
- Clip Sport and Clip Jam are already in MSC mode by default
3. Leave the player connected for approximately 2 to 3 hours to charge.
- The computer CANNOT be in sleep or hibernation mode while charging.
4. Disconnect the player from the PC.
5. Verify if you can turn on the player.
6. Reset the player if necessary.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 376
