メインコンテンツにスキップ
A Toshiba laptop released September 2016, Identification Number C50D-A
9回答 すべてを表示
Help! Toshiba C50D-A Missing Windows 7 Drivers
I've recently purchased a Satellite C50D-A-11Q and back-spec'd it to Windows 7 64 bit. Unfortunately; there are two drivers which, despite hours of searching, I cannot find. One is the Universal Serial Bus (USB) Controller and the other is the graphics driver. I've been in device manager and discovered that the Graphics Chipset is an AMD Radeon HD 7310 and the USB Controller is an AMD FCH USB XHCI Controller. However the correct drivers still elude me. Any suggestions gratefully received.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi ron.atkinson
Just curious on why you need to downgrade to windows 7?
most users should be moving on to windows 10 now.
you can try searching the device driver by using the hardware IDs
example
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I need to downgrade for my job. The software I use is Win 7 specific. I’ve looked in Hardware ID’s but everywhere I look the specific drivers can’t be found :-(
さんによる
コメントを追加
回答を追加する
ron.atkinson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 368
