メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The first generation Honda CRV, produced from 1995 to 2001.
Back up light switch location
Hi guys,
i hope you’re all well!
Im having issues with the back up light switch. It needs replacing. Apparently I can not find the exact location. The engine is 2.0 liter 147 hp manual transmission. If anyone can share exact location or even photos that would be great!
Thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I think it’s the one on the darkest photo?
さんによる
Hi @stoyanr
Your pictures did not show up.
Try posting them again in your question above. Click on Options > Edit > in the Question description bar click on "insert image" icon and follow the prompts.
Alternatively see the link @oldturkey03 provided below
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi again guys!
Thanks for the help!
I found the bastard, it’s located right under the air filter plastic housing. Just unscrew the two bolt on the top of the housing and the unplug the air intake hose.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Hi @stoyanr ,
See the Most Helpful Answer in this link
Why my reverse (backlight) won't work?
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Hi, I went through this topic but still struggling to locate the exact location.
さんによる
@stoyanr it is located on the transmission housing. If you are unsure, take plenty of good pictures of your transmission etc. and post those with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. We most likely can point it out to you. What is the exact year of your CRV?
さんによる
Hi @oldturkey03,
Thanks for the recommendation. Once I get back home I’ll take photo and post them here. It’s 1999
さんによる
Is it on the top side of the housing or on the bottom side? Shall I go underneath the vehicle?
さんによる
@stoyanr it should be on the top half of it. I don't think it will be underneath but it will never hurt to see to much.
さんによる
コメントを追加
回答を追加する
Stoyan Stoyanov さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 34
今までの合計 3,444
