Washer will not start. it just grinds and beeps.
I have a Kenmore Laundry Center model 417.61722510, which is a combo washer/dryer and the washer doesn’t work, but the dryer works well.
it has been turned off until I find a solution for it.
I plugged it in today and it still did not lock the lid, but the engine, or the pump, made a loud noise for a while, about 2 or 3 minutes, beeping a couple of times before stopping the moise. I then pressed the start button and nothing happened, no beep at all.
I already replaced the lid switch, so that was not the problems.
Any help, suggestion with be greatly appreciated.
Regards,
Tony.
この質問は役に立ちましたか?
5 件のコメント
417.61722510 is the number for the dryer, see if there is a number for the washer section
mayer さんによる
I looked everywhere and that is the only number I found. I used the same number to order a lid switch from Sears.
Tony Galvez さんによる
I'm not certain, but it does not seem to be an electrical issue. The noise happens as soon as I plug the machine and is like the engine is revving loudly. In between, at some intervals, I hear the washer beeping. This goes on for about 2 or 3 minutes and then stops. I usually just unplug it.
Tony Galvez さんによる
An update on what I've done so far.
I replaced the lid switch, the washer electronic control board, the laundry center electronic control board, the laundry center washer motor and gear case, and the laundry center washer mode actuator, and the problem remains. Question for anyone of you guys: When replacing the motor and actuator, is there any kind of resetting of electronics/motor to be done?
Also, the only model number I have and there is, according to the Sears guys, if the one I provided earlier. I used that to get the parts I needed.
Thanks for any input.
Tony Galvez さんによる
Did you ever figure it out?
Samuel Willhite さんによる
