will not shut down when I close top
Have to keep adapter on due to laptop not shutting off when I complete using it and I close the screen. Can look through some of the ports and see power is still on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @zardoz3rd ,
Assuming that you have Win 10 installed.
Have you checked the power options settings for when the lid is closed to see if it set for “shutdown” and not some other setting such as do nothing, hibernate or sleep?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 140
1件のコメント
If i want to on the device i cant on and i use charger then can on the device...i dont know what is the problem..can u explain??
muhd さんによる
