Storage Drive Options, m.2 compatibility
What are the storage options for this device?
I assume it has a SATA 3 connection for the included hard drive, does it also have an m.2 connection?
This computer has an integrated Solid state memory and cannot be upgraded. Irresponsible to manufacture a laptop like this.
このアンサーは役に立ちましたか?
I could not find any sata connections when I opened the laptop, though I never flipped the motherboard over, there might be some connection on the other side.
このアンサーは役に立ちましたか?
I have this laptop opened up now and have it flipped around.
RAM and Storage are integrated with no additional slots/sockets
There's only a slot for a Wi-Fi card (which is in use as you might've guessed)
The battery is held in place only by a single screw, so it's easy to replace..
The other side of the motherboard has nothing.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 8
過去 30 日: 50
今までの合計 1,360
