Can I replace my hp pavillion 13-a013cl battery with ese instructions?
My hp pavillio n 13-a013cl takes the same battery i believe. May I use these instructions to replace it?
Hi @hifiguy ,
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.38 to view the necessary pre-requisite steps and then the procedure to remove/replace the battery.
Also on p.38 you’ll find the spare part number for the battery. If you search online using the part number only you’ll get results for suppliers of the part.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 121
