メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
487回答 すべてを表示
Why will my phone not turn on
My phone will not turn on, earlier a yellow light was flashing but now nothing is happening. Here lately it been popping up messages saying things were not working. Like I this one said system processer (I think that what it was called I could be wrong) and something else about my screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Well, on most devices, no power is a battery or charging port problem. Although I have seen a few cases where a damaged lcd would somehow prevent the phone from actually turning on with Samsung devices. I would start with the charging port, inspect it, if anything is wrong with it physically that could be your problem. If not then I would consider the battery if was acting strange in any way before it went out that could be your issue. Both port and battery are fine it could likely be the lcd or possibly even a motherboard problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
taylor_losey さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 41
