メインコンテンツにスキップ
Sony Vaio PCG-5N4Lは2007年から2009年にかけて販売されたモデルで、ウェブカメラとWindows Vistaを内蔵しています。
2回答 すべてを表示
sony viao vgn tz37cn no post no display
Hi, I have a really old laptop sony viao vgn tz37cn that has a broken screen. I replaced the display by carefully checking the serial code and wearing an anti static wrist strap. Everything was fine but after I have done the replacement, I tried to boot up the machine, but there is no display, no hard drive movement. However, the fan is spinning, the power light is on.
I turned off the machine, took off the memory wiped it and put it back, it was still not working. I tried to unplug the motherboard battery and put it back. Still didn't work. Anyone know what is going on out there? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Are you getting logo of sony and then goes to blank Try to restart your computer while pressing F8 and check whether you are able to boot into windows with working display.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Does not show any logo, just black screen, no beep. only the power light is on, and the fan is spinning, no keyboard light as well.
さんによる
No beeps means ram is lose or damged first try to clean the ram and the ram port and after inserting try to reboot while pressing f8
さんによる
コメントを追加
回答を追加する
lesly23 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 331
