メインコンテンツにスキップ
The Huawei P8 Lite is an Android phone, released in January of 2017. Model numbers: PRA-TL10, PRA-TL20, PRA-LA1, PRA-LX1, PRA-LX2, TAG-L21, PRA-AL00X, TAG-L32, PRA-LX3, PRA-AL00.
24回答 すべてを表示
Charging problem followingg screen replacement and water damage
My son dropped his phone into a swimming pool last week - not happy! The front screen and back cover were already cracked so we stripped it down to replace those whilst drying out and cleaning the rest of the phone. It works great - all the apps do what they are meant to do, takes photos etc.etc. BUT it won’t charge. I have changed the battery and USB charging port (and charging cables obviously) but still get a white battery icon which has now dropped down to 30% from 60% when first connected. I have factory reset the phone several times but still the same.The only thing I didn’t change is the flex cable between the motherboard and the battery area (assuming that it was still operational because the phone works in every other sense). Could it be this cable or am I now wasting my time and having to admit defeat. The phone is about 18 months old. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
how did you clean it and dry it out. it may still be an issue with the liquid damage with the water getting under chips and not being cleaned and dried properly
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Following various tutorials I used alcohol to clean. In all fairness there seemed to be very little water ingress.
さんによる
コメントを追加
回答を追加する
Emma Robertson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 181
