メインコンテンツにスキップ
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
What do I check next? Kenmore washer 110.21102012
Kenmore Washer 110.21102012
I have replaced the lid lock switch, striker, control board and actuator in that order.
I have recalibrated it. I did both manual and automatic mode test to which it passed both.
Washer will start a cycle, fill with water, agitate 5-15 minutes and then shuts off completely. It’s getting power. No circuits are tripped. No wires are loose or corroded. I don’t know what to check next.
Somebody please help and point me in the right direction.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@singlemom
since you already replaced the most common items on this washer, check the motor. It may have a bad start capacitor etc. Also make sure that your outlet is working properly. Consider plugging the washer into adifferent outlet and see if that changes anything.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ronica さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 161
