メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
Trackpad: cursor not moving
Got used logic board from ebay and D5802 diode in the booster circuit for trackpad was missing.
Got one from the donor board, soldered in, somewhat it’s now better (trackpad now poorly reacts on taps but still no solid cursor movement), i’ve measured the voltage on the output of this D5802 and it’s only ~11V instead of 18V. It could be i’ve killed it during de-soldering from the donor board, but i suspect it’s either some cap or a resistor gone bad in that booster circuit. The problem is that most of them are covered by the trackpad connector so i can’t measure the voltage in there, and if you unplug the connector there’s no voltage…Anyone can give me a hint please?
thanks in advance.
Update (08/24/2018)
trackpad itself is OK, i’ve tested it on another logic board.
the issue is with this particular logic board’s booster circuit . I’ve inserted the relative portion of the schematics and marked the D5802 diode in question.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Want is your board number?
さんによる
コメントを追加
1 件の回答
ベストアンサー
I tend not to spend time trying to fix the trackpads as often the reson they have problems is liquid damage. I just replace them MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.の画像
製品
$43.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Nurfed Igvaar さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 322
今までの合計 431
