メインコンテンツにスキップ
The 7th generation Honda Accord, from 2003-2007.
Why is a green key flashing in my dash
car crank but want start
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
1件のコメント
my honda civic car key fall in water by mistake after that green key flashing that time what should i do
さんによる
コメントを追加
5件の回答
最も参考になった回答
Hi,
The “green key” light is an indicator for the car’s immobilzer system.
Here’s an image taken from a 2004 Honda Accord owner manual that explains what the problem is when the light is flashing.
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
This step is not working
さんによる
コメントを追加
The fuse is not okay...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Worked thanks fuel was okay thank God!
さんによる
How did you solve this?
さんによる
コメントを追加
The icon of a green key in the instrument panel is normal although many of us never notice it. The green key will come on when you turn the ignition key to the start position. If everything is working correctly the key will blink once and go dark and the car starts. Where you insert the ignition key there is a component around the key hole called an Immobilizer. It is part of the anti-theft device in the vehicle. It’s job is to read the chip in your key fob ,,, if it’s the right information for that particular car, the Immobilizer will inform the car’s onboard computer and the vehicle will start. Every vehicle has its own unique code and is identified by the vehicle vin number. If the code is wrong or the reader is not functioning the computer will shut the fuel and firing systems down and the car will only turn over but will not start , some vehicles will crank up but then immediately shut off.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If you disconnect the immobilizer component will the engine turn over/start or will it completely shut it all down?
さんによる
コメントを追加
@D MyVoice
Open the keyfob and remove the battery.
Then clean the board in the keyfob using Isopropyl Alcohol 99%+.
When it is dry, reinsert the battery and check if it now works OK in the ignition.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My key does not have a opening I have no buttons on my key so I know its not the key doing wrong .my car turns over it might take 3 attempts then it starts but it is getting harder to start I have looked up a lot of stuff to see what the problem is .I guess a trip to the meachinc
さんによる
コメントを追加
Check your fuses it may cause the immobilizer flash light to on frequently..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
roser6 さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 67
過去 30 日: 331
今までの合計 77,621
