メインコンテンツにスキップ
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
28回答 すべてを表示
Mcmulloch MC 1275 Black water in reservior
Is there a chemical I can use to clean out inside besides vinegar ? What about CLR
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
  • Manganese leaves brownish or blackish stains.
  • White vinegar, a weak acid, is about 5 percent acetic acid. It may remove hard water deposits from glass, rust stains from sinks, and tarnish from brass and copper.
  • Lemon juice, another weak acid, contains citric acid, which can be used in much the same way as vinegar.
  • Oxalic acid is effective as a rust remover.
  • Phosphoric acid is often found in cleaning products that remove hard water deposits.
  • Hydrochloric and sulfuric acids are sometimes used in diluted concentrations in toilet bowl cleaners. A dilute sulfuric acid is also called muriatic acid and used to clean swimming pools.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Deb’sMistake さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 198
