メインコンテンツにスキップ
The Motorola RAZR Maxx HD XT926 was released in late 2012. It is one of Verizon's most popular Android based phones boasting dual core processing power and 4G LTE service.
7回答 すべてを表示
How do I get a piece of a staple out of the sd card/sim card slot
I once tried to open the sd card/sim card slot on this phone using a bent piece of a staple. It broke and its stuck inside. I managed to open it while its stuck inside the little hole for inserting the key. ive already tried using tweasers and pliers. when I press on it it doesn't open the sd card/sim card slot.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
unfortunately the phone need to be disassemble to safely get it out
you might end up getting the screen crack for even damaged, damage the spring mechanism controlling the sim and sd card tray popping out if you keep taking the same procedure
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Meme Creme さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 189
