メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
What is the max of logic board upgrade for a A1286 model
I want to upgrade my logic board after it un-operational, but I would like to upgrade it to the latest possible upgrade logic board for the Macbook Pro 15” Unibody Mid 2010 (A1286). I heard the boards are very similar till Mid 2012.
Can anyone please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
4 件のコメント
I have also a broken logic board on my macbook pro 15 mid 2010 and want to upgrade it to the mid 2012 2.7 GHz one. Did the logic board fit or did you had to buy a battery and/or screen converter?
さんによる
I also want the same
curios to know if someone has done that before so that I can also proceed
さんによる
You can add a 2011 logic board (but the antenna cable is a bit short) and the 2012 unibody MBP logic boards have a fourth antenna cable whereas the 2010 logic board has three connections.
さんによる
Wait don't put in those logic boards because they won't fit in the housings due to their thunderbolt ports. If you really want to swap them, get a 2011 or 2012 housing too.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
This would probably be the latest board that will work:
Apple MacBook Pro "Core i7" 2.7 15" Mid-2012 Specs
Identifiers: Mid-2012 15" - MD546LL/A* - MacBookPro9,1 - A1286 -  2556*
https://everymac.com/systems/apple/macbo...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Tamer Osman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 2,648
