メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
209回答 すべてを表示
Why won't my MBP boot from the ext SSD
Had 2013 MBP that died.  Took out the SSD (with iFixit tools) and put it in an Other World Computing USB enclosure (Envoy).  Connects to new MBP 2018 via Other World Computing micro-b usb 3.0 cable with an Apple usb to usb-c adapter.  4 partitions (one aspf and three GUID Mac OS extended journaled) display on the screen and I retrieved the data that was not backed up so that all is well.  Running 10.13.5 and 6.
Then thought I would (for the fun of it) try to boot from the now external SSD.  Nope.  Fails.  See the circle with the line (ie no valid system). Have tried both command-R and system preferences.  Both offer it as boot option.  Have re-installed High Sierra.
Also Disk Utility says the drive is not solid state and is not bootable.
Other World Computing says I need a USB-C to USB Micro-B 3.0 and omit the Apple adapter so have ordered one but...
Why won't it boot?  And why does Disk Utility say it is not solid state and not bootable?
Is true, I retrieved my data so should give up, move on, but am now soaked in curiosity.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The new 2018 models hav a T2 chip in them unlike older MacBook Pro’s. The T2 chip offers a higher degree of security! As such somethings are a bit harder unless you tell it not to do something. Here is a good Apple T/N which reviews the different security levels About Secure Boot your system has.
Click on the External Boot ‘Allow Booting from External Media’ should resolve your issue.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
thank you but
is already set to allow ext boot and I have other ext drives that boot
also set to no security
will keep piddling with this
さんによる
Was the drive protected in some way?
You may need to send the drive out to someone who can recovery it as it might have been damaged.
さんによる
Thanks. The SSD drive shows on the desktop so I recovered all files. But now that I have it, I thought would try to boot from it. And cannot figure out how to make it boot reliably.
さんによる
Try this hold the Option key when you reboot the system that will allow you to gain access to the startup Disk manager, then select your external that should do it.
さんによる
Thanks but more than half the time it does not show up with Option boot, even if I connect the drive at the time the drive selection appears.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Loren Engrav さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 1,042
