メインコンテンツにスキップ
HP Officejet Pro 8620は、コピー、スキャン、および両面印刷用の多機能プリンターです。 このデバイスは、モデル番号SNPRC-1401-02で識別できます。
18回答 すべてを表示
Removal of the right side of the case of an Officejet Pro 8625?
I cannot for the life of me figure out where to unlock the right (*edited) side panel near where it attaches to the paper feeder. I see the tabs on the underside and the entire thing is separated except in that area where the light grey part I’m trying to pry apart presses against the black plastic for the paper feeder.
I’ve been able to remove the left panel and back panel with no issues, just stuck on this side here. Anyone have any tips?
Thank you ahead of time for any help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I know I’m late to the party but, just for anyone who needs to know in future, if you look inside the printer from the front on the paper exit tray you will see two little tabs that you can push down. This will allow the paper exit tray to be removed revealing a small screw that holds the panel in place.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It doesn’t come off as illustrated in step 4 here…
HP Officejet Pro 8620 Motherboard Replacement
The text says “pulling down” there but down in the photo would actually be toward the back (normally verticle) side of the printer.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This is what happens when you spend too many hours messing with a printer--I actually meant RIGHT side. It's currently upside down and my brain is no longer cooperating. Thank you for the answer. That side is a breeze, it's the other that I'm having a disastrous time with.
さんによる
コメントを追加
回答を追加する
Tammy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 790
