Can I replace a 240v power supply with a US standard 110v?
I purchased a non-US PS4 Slim. It requires 220-240v to operate and I’m wondering if I can replace the power supply to use it within the US?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi!
The PS4’s power supply is designed to work internationally, which means it will take both 110V and 220V without any issue. All you need is the right power cable.
このアンサーは役に立ちましたか?
That’s great to know. The back of the device explicitly says 220-240v and I just tested it on a 110v circuit. Works perfectly. Thanks for the help!
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 46
