メインコンテンツにスキップ
The Chevrolet Equinox is a compact crossover SUV from Chevrolet based on General Motors's Theta unibody platform, and introduced in 2004 for the 2005 model year.
136回答 すべてを表示
Why is my car not charging
I have had alternator tested and battery tested. The fuse link is good and all fuses good. I'm getting 5.3 volts at orange wire out of pcm. And also the battery light on instrument cluster works. Please I need help. Thanks. Also I forgot its a 2005 chevy equinox.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
parrisheq4  the battery light etc. gets its signal form the BCM. The PCM (powertrain control module) seems to be the one that determines the charge from your alternator. since you are showing the 5V I wonder if this is not a faulty battery current sensor. I would try to have the OBD scanned to see if you get a code of any kind.
This might guide you toward a few things you can check without the GM tools Printing from undefined No idea about what it says regarding printing……;-)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
parrisheq4 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 2,194
