メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
iPhone 8 plus no service(sim card can't read) after water damage
iphone 8 plus no service(sim card can’t read) after water damage
Hello all how are you?
Dropped iphone 8 plus into the water then I cleaned mother board by alcohol
everything works fine except no service network carrier
i think something wrong with cellular antenna
which part i need to replace?
maybe charging port? thanks all
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
There are a few antennas being used (mainly the antenna cables near the charging port are used for cellular 3g/4g) and a few things you should check is if imei is displayed when dialing *#06#, also modem firmware and imei displayed in settings > general > about phone.
I would expect some board-level repairs needing to be done after liquid damage.
I recommend taking the phone to a reputable repair shop that does board-level / liquid damage repairs for liquid damage evaluation.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
My phone does the same thing but not water damage. It connects to wifi but that's all it says no service
さんによる
I have a few of these as well, liquid damage that shows no modem firmware after but everything else works.
さんによる
コメントを追加
回答を追加する
Kyuho Lee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,493
