Nano sim stuck in sim slot
I accidently inserted a nano sim in the sim slot and now its stuck. How can I get it out without damaging anything.
If you are fine with a bit of a hacky solution I have found staples are often quite useful for this sort of thing.
If you have a stapler just staple nothing, collect the staple, and then unbend the prongs into the shape you need. Then just stick it in the slot and wiggle it about to try and lever the SIM card out. I think its unlikely you would damage anything since I don’t think the connections would be very sensitive.
このアンサーは役に立ちましたか?
I tried it but I'd didn't work
So I unscrewed anything in my way took everything apart and was finally able to get the sim card out
Thank you for your suggestion
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 307
