I have a 100 series kenmore top loader which does not fill all the wa
why doesn’t my washer fill with water, it only puts a small amount of water in the tub.
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
このアンサーは役に立ちましたか?
There is a water leveling sensor you should check. Check out some of the “you tube” videos for your make/model machine. They helped me fix mine!
このアンサーは役に立ちましたか?
There’s nothing wrong with it.
I thought the same thing when I got my machine and it was brand new.
I found it very strange that it wouldn’t fill with water ,so I called after many many tries. I finally got my answer ,which was there’s nothing wrong with it. It’s supposed to do that. The machines are energy-saving which means they save water.
Believe it or not, although they saving water, they’re very efficient machines just try not to overload it.
このアンサーは役に立ちましたか?
Now it will not fill period
What is the model number of the washer?
Have you checked that the water supply faucets that the washer hoses are connected to are turned on?
過去 24時間: 4
過去 7 日: 20
過去 30 日: 103
今までの合計 2,690
3 件のコメント
@popstogo what is the exact model number of your washer?
oldturkey03 さんによる
11020222511 is the mod number
victor lopez さんによる
These machines are energy, saving, which means they save water
I thought the same thing when I got mine it was a brand new. Why wouldn’t it fill with water .? checked and checked got my answer. which was what I’m telling you ,there’s nothing wrong with it.
Walter Arzon さんによる
