Phone is not restarting..
my phone produced a beep sound and than turned off i left it for several hours but still it is not turning on charge was more than 70%.what should i do now???
the first suspect should always be the battery, regardless of what percentage it shows. It is not a good indicator of the condition of the battery. Start by checking a few things like this
You can of course always try a hard reset as well:
1. Turn off the phone.
2. Press and hold both Volume UP and HOME + power on the phone. Keep pressing the VOl + home.
3. When Android Recovery menu screen appears release all keys.
4. Navigate and highlight "wipe data / factory reset" using the Volume down key and press power.
5. Navigate and highlight again to Yes -- delete all data and press power.
6. All data will be lost! Before doing a hard reset backup all important data.
After hard reset is done select Reboot system now. Press power to reboot the phone.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 67
