メインコンテンツにスキップ
Xiaomiスマートフォンの修理ガイドです。
1717回答 すべてを表示
[Redmi 3 pro] Loose cellular network when back cover clipped back on
Device : Xiaomi Redmi 3 pro
After replacing the battery, the mobile network doesn’t work when back cover is properly clipped back on. After testing, it works fine without the back cover and absolutely not when back cover is clipped back on.
I double checked all the internal connectors (one was bent so I straightened it back) and tape antenna. I tried loosening or tightening screws. I tried to replace the old battery (matter of the 1mm difference) without success.
I lack magnifying glass so not easy to check if a component is damaged (but why would it work without the back cover?).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It sounds like something is blocking or causing interfarance . Try removing all the screens n put the black cover on to see if that fixes it. If it does put one screw in at a time then check to see if it still working or not .
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'll give it a try at some time.
Not sure it will fix as I already tried to loosen screws without success.
Putting the SIM card in the other port gives various results but ends up failing.
さんによる
コメントを追加
回答を追加する
Nick TNTPOP さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 62
