メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Mower will not start with key
Problems started with a motor choking with excessive gas ( removed and cleaned carb).did not cure the problem. Started the mower again and let it run at 1/3 speed and ran normally. Engaged the mower deck and choking started right away and then stopped.
After dis- engaging the deck I tried to start the mower with the key switch and it would not . Leaving the key on ,I was able to start the motor by jumping the solinode. Still choking at medium to high speed and now no deck engagement when I put up the knob on the dashboard. Also noted at this time that the running hours meter also was not working.
Would the seat safety switch cause all of this? Or the key switch?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
shavorhead  all of this sounds like the key switch. It appears as if it does not close all circuits. I’d start with a replacement. If nothing else it will provide you with a know-good starting point for further troubleshooting. Also, give us the exact model number for your mower
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
shavorhead さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 77
