Disk usage 100%, nothing running
So task manager shows my disk usage is 100%. I am currently not doing intensive pc work. What is causing this problem and how can I fix this? Screenshot included
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Had this problem on a number of computers running Windows 10.
Current (March 2019) Windows 10 Updates fixes most of this high drive activity.
Spy-Bot’s Anti-Beacon software will block most of MicroSoft’s snoopy telemetry software which also causes much drive activity.
このアンサーは役に立ちましたか?
This is very common in windows 10. I wasn’t happy when mine was doing this so i installed an SSD. Problem solved
このアンサーは役に立ちましたか?
Everything worked well before, a couple of months now my pc is getting slower.
The computer is busy because Windows 10 is doing one of its many updates. Currently (2018) the only easy workaround is : let it run some hours while you are away…
For more help, you may read “Why are Windows 10 updates so slow? “ (may 2018) : https://www.techadvisory.org/2018/03/why...
このアンサーは役に立ちましたか?
How to protect computer from cryptojacking
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 573
1件のコメント
I have a Alienware x51 R2
Ruben Debbaudt さんによる
