The Home button has ceased to function
The touch screen still works perfectly, but I’m getting no functionality from the Home button at all. I can’t end an app without powering down and restarting the iPad.
well i mean, the most likely scenario is that you need a home button replacement, but before going through the labor, do a settings reset first. if that doesnt work, move on to the replacement.
iPad Mini Home button Replacement
This is the replacement guide. pretty simple as far as soldering goes.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 12
今までの合計 626
Next time you power it up, go to Settings/General/Accessibility/AssistiveTouch and enable that. At least it will make the iPad usable until you fix the Home Button.
Minho さんによる
Unable to get to settings
Debbie Centrella さんによる
