Sony KDL-75W850C 6 red blinks - where to measure LED voltage
I am troubleshooting a Sony KDL-75W850C per the service manual. 6 red blinks indicates either bad power board or LD panel. I have checked power board and I have good 3.3v STBY, 12V, and BL_ON. . It says I need to measure the LED output voltages. I assume I measure them between OUT+ and OUT- on the board. All the other points are measured to Ground. The reason I ask is I get a brief pulse of 132V between OUT+ and OUT- then it collapses to 0. If I measure between OUT+ and Ground I get varying voltages from 0 to 200V ( I assume a cap is charging discharging).
この質問は役に立ちましたか?
4 件のコメント
My friend, I’m struggling to have access to the backlight panel.. do you have a service manual or can you give me some tip where I canget there? I’m in a point now where the TV is 80% disassembles, but I don’t know how to proceed to take the LED panel appart from the LCD screen. Thansk a lot . Eduardo
djedumolina さんによる
It has been a while. It seems like once I removed all the screws I was able to get the back off to see the circuit boards. From there I don't remember the process to get to the panel but it seems the bezel was difficult to seperate. Sorry, I can't be much more help. FYI, two years later, another strip went out. We decided to scrap it at that point.
Bruce White さんによる
Having the same problem, looking for information on how to replace the strips. If anyone can help or point me in the direction that would be great.
Nelson justiss さんによる
@nelsonjustiss it'll depend on your TV's model number. To replace the strips is fundamentally the same on all of this LCD TV's. Take a look at something like this guide It'll be pretty much the same way. The issue is that the larger the TV the easier it is to crack the LCD screen. Amazingly enough they are pretty flimsy and love to flex. To find a backlight array (strip) it is best to get the LCD assembly number of the sticker affixed to the back of the display. Do an online search and see what you find. Of course, if you have the number already or if you are not entirely sure, let us know what it is and we can most certainly try to assist you with that.
oldturkey03 さんによる
