iPhone 7 shutting down randomly
I have a customer that has a iPhone 7 it keeps shutting off randomly even after battery replacement and software up data and DFU restore.
any other reasons this could be doing this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
A lot of things can cause the phone to randomly shutdown. Did the customer share any history of the device, such as previous repairs, drops or other impacts, cheap chargers etc.? I know you said randomly but have you or the customer been able to see any form of pattern, such as usage, apps, conditions or modules being used (camera etc.)? If it is truly random, it will be hard to figure out.
Start with a really thorough inspection with a microscope. Look for anything out of place or normal, such as traces of water (even if the LDI’s are good), dislodged or partially dislodged components. I like to nudge the coils as sometimes they are barely hanging on and can cause intermittent problems. Just don’t nudge too hard :>).
このアンサーは役に立ちましたか?
First check the BSI ways or the center pin of the battery connected properly or not.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 905
