Mine plays the cassettes to fast
It plays the cassettes to fast does anyone know how to fix that?
The speed of the tape is controlled by the pinch roller and the motor that turns the pin next to it. If the tape is moving too fast, then this is either not moving the tape and the take-up reel is moving it or the motor speed is wrong. If your unit is the WM-AF48, any belts should be changed and the pinch roller at least cleaned if not also replaced. This should solve the problem.
Dan
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 17
今までの合計 3,589
I’ve had this issue before on a Walkman,
It is the Idler Gear, there is a speed adjuster near that gear.
Can you open it up and post pictures?
Repair Pug さんによる
