Enter button not working
My battery leaked acid yesterday and after cleaning it up, the calculator worked perfectly. However, today when I went to use it, every key worked except for the enter key. What can I do?
You can try to repair the button using this guide here. However, the corrosion may have permanently damaged the button which will require a motherboard replacement. You can’t buy new motherboards, but if you can find a calculator with damaged screen, the motherboard is still probably OK and you can salvage it out of the broken calculator. There’s a guide on motherboard replacement here.
ガイド
難易度:
中レベル
5 - 15 minutes
ガイド
難易度:
中レベル
10 - 20 minutes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 3,309
