Tablet damaged by water
my tablet is samsung Tab s2 9.7 and it damaged by water so touch it’s perfectly work whole screen but the bottom of screen its kinda dark but not very dark like you can see the items ,so what should i do ?it needs new lcd?
John Watson the very first thing you want to do is stop using it. Then disassemble it using guides like this Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement. Clean everything with a high grade isopropyl alcohol 90%+ and a soft brush. Use this guide iPhoneの水濡れ・水没ダメージからの復旧方法 for that. It was written for an iPhone but all the points are still pertient to yours as well. Once done, you could reassemble it to re-evaluate or you can take your chances and repalce the screen Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement since it seems to have taken most of the damage.
ガイド
難易度:
難しい
1 - 2 hours
ガイド
難易度:
中レベル
20 minutes - 1 hour
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 720
