メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
iPhone won't charge but logic board gets warm
Okay so I was recently changing an iPhone 7 screen and I unplugged the battery from the logic board. I know it’s stupid but I didn’t realise the screen was still turned on. Now when I charge the device it no longer turns on or shows any response. However, after a while the logic board gets warm. I’m not an expert so I need a little help. It’s definitely not the screen because it was working before. The backlight is fine and the charger is working. Any ideas as to what the problem might be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Did you try a soft reset? Just asking,trying to see what troubleshooting you did.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I held down the power and volume down buttons for a while. Didn't work. The battery had issues before I even worked on the phone as well, it hadn't been turned on since December.
さんによる
Did you try unplugging the battery and plugging it back in because it sounds like you did the screen replacement with the battery plugged in the whole time.
For doing any screen repair it's good practice to unplug the battery first if possible or soon as possible.
さんによる
It's quite confusing but I actually successfully completed the screen replacement to test the actual screen. Then I did it all again to fit in the home button, that time it wouldn't charge again.
さんによる
コメントを追加
How do you know all these things are working if you are getting no response from the phone? do you have a power monitor you can hook it up to and see if you are pulling anything at all??
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I don't have a power monitor, but I know these things are working because they worked literally seconds before. I checked the backlight with a flashlight and the charger works with my other phones. I tried the old screen (which was cracked but working) and still no response.
さんによる
Do you have a multimeter to test circuitry? You may have shorted something when you disconnected the battery. There is definitely some testing that will need to be done before you can find a solution or verify parts work.
さんによる
コメントを追加
回答を追加する
Tahiyan Choudhury さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 66
